The important thing is to have all of the light consistent in color. 5000k is often recommended as close to daylight and therefore integrates well if daylight is a part of the light being used. In a dark room or after dark with only artificial lights then the actual color is not as important as having it all the same. Then shoot in RAW and color correct if you have to in post processing.
As stated above, source something easy to find and stick with that. I am using all 5500k compact fluorescent bulbs right now. The local store has a brand they stock that is not too expensive and works well. Personally I would avoid incandescent bulbs and use compact florescent if they available there because of the less heat given off and less cost to run them. Many CFL brands here now list the color temperature. The local grocery store has 2700k, 3800k and 5500k to choose from.
