Pentax/Camera Marketplace |
Pentax Items for Sale |
Wanted Pentax Items |
Pentax Deals |
Deal Finder & Price Alerts |
Price Watch Forum |
My Marketplace Activity |
List a New Item |
Get seller access! |
Pentax Stores |
Pentax Retailer Map |
Pentax Photos |
Sample Photo Search |
Recent Photo Mosaic |
Today's Photos |
Free Photo Storage |
Member Photo Albums |
User Photo Gallery |
Exclusive Gallery |
Photo Community |
Photo Sharing Forum |
Critique Forum |
Official Photo Contests |
World Pentax Day Gallery |
World Pentax Day Photo Map |
Pentax Resources |
Articles and Tutorials |
Member-Submitted Articles |
Recommended Gear |
Firmware Update Guide |
Firmware Updates |
Pentax News |
Pentax Lens Databases |
Pentax Lens Reviews |
Pentax Lens Search |
Third-Party Lens Reviews |
Lens Compatibility |
Pentax Serial Number Database |
In-Depth Reviews |
SLR Lens Forum |
Sample Photo Archive |
Forum Discussions |
New Posts |
Today's Threads |
Photo Threads |
Recent Updates |
Today's Photos |
Quick Searches |
Unanswered Threads |
Recently Liked Posts |
Forum RSS Feed |
Go to Page... |
Search this Thread |
11-22-2007, 09:30 PM | #1 |
Flash questions for my K100
I have a K100 and would like to add a flash. However, I have never used one before and have some questions: 1. I normally use my camera for family photos. 2. What am I looking for in a flash? 3. Could you suggest some flashes? I dont need a $500 flash. Anything between $100 - $300 would be about right. 4. Do you know anything about the af-500 flash? I have seen this one advertised for $20?!? 5. Does swivel matter? I am assuming most flashes move up and down for bounce, so when the term "swivel" is used, it is referring to the ability to turn left and right. 6. Is recycle time important? 7. What does "54 at iso 100" mean? I know what the "iso 100" part means, but what does the "54" refer to? Also, my camera starts at iso 200, so how does this translate? 8. What does "ttl" and P-ttl" mean? What does it mean specifically in response to the K100? 9. I've seen some forum discussions where people say they can only use their flash in manual or automatic. Does the flash connect to the camera where I cant use automatic focus? Do I only get to use manual focus? 10. Do you know of any websites or articles that discuss different flashes and the terms I have asked about? 11. Would you only recommend Pentax flashes with my K100 or would you suggest any other brands? Thank you so much. | |
11-22-2007, 10:53 PM | #2 |
Wow, lots of questions, but you've probably come to the right place with them... Firstly, I'm close to being in your situation in that I have a K100D and mostly use it for family shots, but I occasionally do small paid jobs too. The in-camera flash is handy but doesn't produce very flattering shots. So in your case, especially if you're not doing paid work with your camera, a P-TTL flash (ie. the more expensive flash units that automatically calculate required flash intensity for the settings on your K100D using pre-flash exposure metering technology) would be more a convenience than a necessity. Having said that, the prices of third party P-TTL flashes are going down and are within your budget, but as discussed on many other threads, are generally not as good as the original Pentax P-TTLs. The K100D cannot utilise the TTL function of a TTL flash, which doesn't use pre-flash to calculate the required settings. Other more experienced people on this forum would be able to explain these concepts better, though - I'm definitely no expert on flash technology. But what I can comment on is an alternative setup that I've been happy with: Having a good auto flash unit (which does not communicate with the camera, but uses a light detector to calculate how much flash it should discharge for a pre-set aperture and distance) and switch your K100D to M mode to enter in the aperture and shutter speed (bear in mind, the fastest shutter speed you can have is 1/160). Then shoot and check out the histogram. By the way, auto doesn't refer to auto focus, and manual just means the flash unit throws off a consistent amount of light each time (for many units, that's just full power, but some units can have 1/2 or 1/4 strength flashes). That's quite simplistic, but I could go on for much longer on marrying flash settings with the camera settings for a good exposure. It all depends on what you're shooting and where you're shooting it. IMO, a flash with tilt and swivel is a must - there have been many occasions I've used my swivel flash and would not have had the results I wanted without it. But using an auto flash with the K100D takes practice as well as the knowledge of flash fall-off, bounce angles and all that jazz. You may have to do a little research as to the meanings of guide number and ISO sensitivity. They are as important as aperture and shutter speed in flash photography. Basically, in the words of a non-pro, guide number tells you how powerful the flash unit is at a particular ISO - the higher the number, the more powerful the flash, but be sure to compare numbers using the same ISO and units of guide number (feet/metres). At ISO 200, the guide number will be about 1.4 times more than that at ISO 100. Check out how to calculate and use guide number from a good flash tutorial, as well as bounce flash techniques - it's a very good skill to develop. This is a basic website on bounce flash: Lighting tip - 4 ways to bounce a flash | DIYPhotography.net This is another site on general flash photography: Flash Photography Made Simple Here is a comprehensive series of flash photography tutorials, focussed on Canon cameras but is very informative: Flash Photography with Canon EOS Cameras - Part I. I'm sure there are many others, but these should help out a little... I've said enough and let others comment and answer your other questions... Cheers. Last edited by Ash; 11-22-2007 at 11:38 PM. | |
11-22-2007, 11:24 PM | #3 |
Here's my stab at your questions. This is just one person's opinions, so take them with the proverbial grain of salt. Quote: 3. Could you suggest some flashes? I dont need a $500 flash. Anything between $100 - $300 would be about right. Quote: 4. Do you know anything about the af-500 flash? I have seen this one advertised for $20?!? Quote: 5. Does swivel matter? I am assuming most flashes move up and down for bounce, so when the term "swivel" is used, it is referring to the ability to turn left and right. Quote: 6. Is recycle time important? Quote: 7. What does "54 at iso 100" mean? I know what the "iso 100" part means, but what does the "54" refer to? Also, my camera starts at iso 200, so how does this translate? Using a higher ISO makes more your camera more sensitive to light, meaning the same flash brightness can be used farther away. At ISO 200, you're twice as sensitive to light, so you can move to a distance that allows half as much light to reach the camera and get the same exposure. That's not twice as far away, it's actually 1.41 times as far, because light falls of with the square of distance. So in the example above, using ISO 200 lets you get up to 9.5 meters away at the same f-stop. You don't have to do these calculations, the flash unit will show you graphically what it's effective distance is when you use P-TTL mode. Quote: 8. What does "ttl" and P-ttl" mean? What does it mean specifically in response to the K100? Quote: 9. I've seen some forum discussions where people say they can only use their flash in manual or automatic. Does the flash connect to the camera where I cant use automatic focus? Do I only get to use manual focus? Quote: 10. Do you know of any websites or articles that discuss different flashes and the terms I have asked about? Quote: 11. Would you only recommend Pentax flashes with my K100 or would you suggest any other brands? | |
Bookmarks |
Tags - Make this thread easier to find by adding keywords to it! |
camera, flash, flash questions, flashes, focus, iso, k100, lighting, photo studio, questions, strobist |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Several flash questions | bniece | Flashes, Lighting, and Studio | 1 | 07-13-2010 11:04 AM |
Pentax K100 Super flash question | pentaxable | Troubleshooting and Beginner Help | 5 | 11-23-2009 02:09 PM |
Radio-link flash for both K100 and K200 | peterh337 | Flashes, Lighting, and Studio | 0 | 01-18-2009 09:08 AM |
Battery pack for flash, and other flash questions | reknelb | Flashes, Lighting, and Studio | 2 | 12-09-2007 07:30 AM |
New member w/ some questions about the K100/K10D | skydragoness | Pentax DSLR Discussion | 33 | 09-26-2006 02:12 PM |
