Hi,
1. I can't get this to fail, with the flash set to remote it works for me at f16 even. You haven't accidentally set the shutter speed to greater than 180?
2. You have to control the flash output by setting the flash itself to manual and adjusting the power on the flash itself, I believe the wireless slave mode is limited to P-TTL control
3. You can use a Pocket Wizard on the Pentax & Metz but you are still limited to adjusting the flash to manual or automatic mode, there is no system I know of that wireless sends P-TTL signals to remote flashes in the Pentax universe. Yes, Nikon does allow wireless control of remote flashes including power setting, I don't know about Canon, not owning one.
No such thing as silly questions.
Actually, if you get into any studio lighting with the Pentax and larger strobe lights you'll find that your almost back to the sync cable world, just substituting the sync cord with radio transmitters & receivers instead and adjusting the strobe lighting power manually. Full circle as it were.
Reason: Adjusted reply for point # 1
