Originally posted by Class A True, one can mod them, if one is so inclined.
Does the modification reduce the battery life?
Not that I've found - I've been using 2 TX's without issue on the original batts now for at least 2000 Frames/8mnths... One as a trigger and one in the hotshoe.
I've also not had a hint of shutter curtain and shoot at 1/180 a bit (I'm loving X-Mode these days
Originally posted by elliott Anyone know if the 603 fixed that problem?
Entirely no workies with Pentax due to their new support for Canikon TTL's....
And the reason it doesn't work is its multi-vendor compatibility and the way Pentax's shoe is pinned out - which is orientation wise a match to the Nikon shoe where the 'ready' pin on Nikon (Which goes high and stays high) is the Data pin on the Pentax (Which floats all over the shop)... this causes the ready signal to be pulsed which is what the 602's use to open a carrier to ensure 1/180 timing over the 100m+ range... without the 'ready' pin (or with it flashing) it as you know causes issues above 1/160. The 'half-press' trick - which is also used to enable Auto-Focus when used as a trigger - uses the same carrier wave which is why this also fixes the 1/180 'issue'....
My solution is to just stick a capacitor across the ready pin and ground - acting as a filter to the data signal and making the unit go 'ready' on any activity on the Data pin - which as its used for TTL communication it happens to coincide with the Lightmeter - the unit goes 'ready' for as long as the Camera Body is Metering.... To do this 'at the factory' they would need to add a capacitor and a switch to choose Nikon/Pentax etc; since they've now moved on to the 603, stripped the Sync port off of the 602 and rebadged it the 600 (TX Only); I wouldn't hold my breath we'll see it sorted out for Pentax any time soon. (But they'll make the 602's for a while yet - they still make their original triggers, the PT-04/CTR-301's!)
Long story short - They work 100% for me (honest - only misfires are when I forget to turn a Remote on!
) and no hint of curtain (Cept when Remote batteries are dead/going flat) - but I have the tiny Cap's lying around and a solder station on my desk - so for some, maybe the Cactus are an 'easier' way to go if they are just as cheap...
