Originally posted by dj_saunter I shoot film on my Super Program and Program Plus a lot, but I also use my K10D.
I want to learn more about flash photography so I was wondering if there are anything that I need to consider when buying a flash that would work on both.
The program plus and Superprogram support the Pentax "TTL" mode while the K10D uses a different method called by pentax P-TTL.
If you buy a current model Pentax flash such as the AF-360-FGX, it should work on all of your camera bodies. None of the older Flashes will work on the K10D---unless you consider working---using the manual mode....
