Originally posted by 2grahamb You wrote: In "dumb" auto mode, you have to match the ISO and the aperture settings on the flash with those on the camera body.
But I also wrote: The more "advanced" Metz flash models (40MZ, 54MZ, 58AF, ...) have what is called "smart" auto mode.
When the Metz flash is dedicated to the camera (as in your case), it has only "smart" auto mode. It does not have "dumb" auto mode. I know, that's silly!
In "dumb" auto mode, you can set the aperture value on the flash (as you can see when you the flash is on and the camera is off).
I have several Metz 54MZ-3 and -4, they have the same problem. When I need the "dumb" auto mode, I use a Metz module for Nikon instead of the module for Pentax (the Metz 54MZ can be dedicated to different camera bands, depending on the module in use).
Interestingly, the current Pentax flashes don't have smart auto mode. Maybe this is the reason why Pentax doesn't implement it?
Originally posted by 2grahamb When you turn the camera back on does the flash just reset to the previous settings, though?
No. When the camera is on, it talks to the flash and the flash will set its aperture to that of the camera.
The only way in your case to have dumb auto mode is to block the data pin(s) between the flash and the camera. I think that's too much trouble.
Edited to add:
I think I was still not clear. So in order to use flash auto mode to fill in the shadow, this is what you have to do:
1. Set the camera to manual mode. Set the aperture and the shutter speed to correct exposure based on ambient light (make sure the shutter speed is 1/180 sec or lower). If you want to use the green button on the camera, you have to turn the flash off and back on when you've done with using the green button.
2. Set the flash to auto mode (note that the flash takes the ISO and aperture settings from the camera). Set the EV comp. on the flash to -1.
3. Take the photo.
