Originally posted by Digitalis no it doesn't- but in the splendidly designed case the pentax AF160FC ringlash comes in you have adapters from 49~67mm at your fingertips.Personally I use the AF160FC with primes Zoom lenses especially the DA*16-50mm f/2.8 SDM extend quite a bit at the front (though there are a few out there that do not) and putting a heavy ringflash on the end of the lens is just begging for some mechanical issues to develop later on. The AF160FC flash tubes are significantly larger than what is used in competing flash units the sigma uses 60mm flash tubes the pentax ringflash uses 120mm semi-toroidal flash tubes, which can throw out quite a bit of power even though there is a built in diffuser in front of them.
Yeah I wondered about the extending zoom vs weight thing - obviously thats not an issue with the DA*50-135, but then given the increased minimum focal distance, would it be much less effective in range?
TBH, I could see using this with my primes and studio shoots, but was really hoping to be able to use it for the music festival stuff (and my main lens there is the 16-50).
Aah, will have to wait till there's another Adelaide macro session or something and see how it goes. Certainly havent seen them in any shops locally.
