Originally posted by Nass I'm hoping to try some reverse lens macro fluorescence shots
For that application I would recommend a continuous UV light source* as opposed to using a flash because the amount of UV light from the flash tube gets swamped by the amount of visible light that is produced - and you would end up wearing out/overheating the flash tube that much quicker. Also be aware that SMC coatings and the glass types used in photographic lenses will absorb UV light as well** which will in all probability extend exposure times considerably.
*UV fluorescent lights, UV LED's
**depending on the frequency of light you are using the rule of the thumb is the higher the frequency > the longer the exposure times will be, which is not all that dissimilar to the approach used for IR photography. Lower frequencies > longer exposure times involved.
