Originally posted by ROBEFFY Hi,
I've owned this combo, with a Pentax 16-45 F4 lens for some time and have not been able to get point and shoot results.
The flash does not display PTTL at any time, unless I set the ON switch to the center setting, which appears to be Wireless?
I get lots of under or over exposed shots.
My best results seem to be on manual mode?
Is this normal?
The owners manual does not suggest what camera settings, ie, Tv, Green, etc to use.
From web scraping it looks as if this flash is not always consistent in operation, wondering what other people have one to get consistent good pics in a family
get together setting, or a meeting type setting?
Regards,
Rob
Funny, I have used it quite successfully in P&S mode, mostly indoors at parties and family gatherings. Generally I use my FA-J 18-35 F4-5.6 so the 16-45 should behave similairly.
One thing I have noticed is a tendancy for the flash to not always push completely onto the shoe. this could give you problems also, but i have never has ggross errors in exposure. generally, in close quarters I bounce it off the ceiling.
I should point out that I shoot in manual mode, and generally have the flash do 75% or so of the scene illuination.
I have had some mized results in AV and other auto modes because the camera tries to meet the exposure first without flash, and then add flash for what ever is left. this can lead to blurred images, ghosting and all sorts, because the shutter speed will be dropped to the hand old limit, which cna be quite slow
