11-14-2011, 03:43 PM   #1
Wireless Flash Trigger Recommendation
Hello,
I was wondering if anyone could recommend a brand of wireless flash trigger that falls somewhere between the cheaply-made $20 E-bay triggers and the Pocket Wizard?
Thanks,
Robert
11-14-2011, 04:19 PM   #2
Cactus V5, Yongnuo RF-602, and Radiopopper JRX triggers are the first ones to pop into mind
11-14-2011, 04:21 PM   #3
Thanks I'll check these out.
Robert
11-14-2011, 08:56 PM   #4
liukaitc's Avatar
I use this
Impact PowerSync16 DC Radio Slave System POWERSYNC16D B&H Photo
one set is 149..
perfect customer review
11-14-2011, 11:44 PM   #5
maxfield_photo's Avatar
The Cactus V5 gets my vote, just a really solid trigger, it never misses even at long range and through walls. I think I paid $68 for a set after shipping. They ship from Hong Kong though, so it takes about 2 weeks, don't know if that's a deciding factor.
11-15-2011, 12:19 PM   #6
QuoteOriginally posted by adpo Quote
The 602 uses the half-press to send some data so on some Pentax bodies (different pin behavior than Nikon/Canon), you might get no more than 1/125th sync speed before you have black bars. I reported this a while back. Some people have no problems, but others do.
I've been using RP JrX happily....remote control of speedlight/strobe power levels is something you get addicted to once you try it. Only negative is no Einstein support yet despite asking them for a year
11-15-2011, 12:25 PM   #7
Reviews of the Cactus v5 can be found here: Cactus Cactus V5 Duo reviews - Pentax Camera Accessories: Database and Reviews.
11-15-2011, 03:29 PM   #8
QuoteOriginally posted by kenyee Quote
There is a simple modification involving a capacitor that will fix that, it only works on the Nikon version.
11-15-2011, 04:05 PM   #9
This sounds interesting. I started browsing their site.
So you are using Canon/Nikon flash that have TTL?
Having the ability to control power level remotely would make the sad Pentax wireless flash situation a bit better.
11-16-2011, 02:33 PM   #10
QuoteOriginally posted by sjwaldron Quote
Yep...the Nikon compatible flashes are better. Their quench pin timing isn't programmable and it seems like they developed it w/ Nikon flashes, so the Canon ones don't have as many power level adjustments.
Non-Nikon flashes also work as long as they have the TTL quench pin for old Nikon film bodies.
11-17-2011, 04:01 AM   #11
Paul Buff Alienbees Cybersyncs.
Transmitter: Paul C. Buff - CyberSync Trigger Transmitter
Receiver: Paul C. Buff - CyberSync Receivers
For the receiver you have a choice of AC-powered or battery powered. If your flash doesn't have a pc port, you can get this adapter: FlashZebra.com: Female Hotshoe with Miniphone Jack (female) (Item #0128)
11-17-2011, 09:19 PM   #12
DaveHolmes's Avatar
I have the Cactus V4's and they work great... Can only assume the V5's are an improvement...
11-24-2011, 08:16 AM   #13
yoon395's Avatar
Another vote for the Cactus V5
Midwest Photo sells them here in the states if you're willing to pay a few extra dollars to get it quicker
11-24-2011, 08:25 AM   #14
Thanks everyone for your suggestions -- I had done a little research before I posted this inquiry, but I hadn't run across the Cactus, the Paul Buff or the Impact lines -- proof of what a great resource this forum is.
02-27-2013, 06:09 PM   #15
Hi,
Sorry to dig up such an old thread! I just want to make sure I understand this correctly. I've got a Pentax K-5. If I bought a Nikon flash that has TTL, and a set of RadioPoppers JrX, then I could use the Nikon flash, with my Pentax camera, in manual mode, and I could control the flash power levels remotely?
TIA,
Daniel
flash, lighting, photo studio, strobist
Phottix Tetra Wireless Flash Trigger slip Flashes, Lighting, and Studio 3 06-22-2013 04:45 AM
NPT-04 Wireless Flash Trigger fotomanic Pentax K-r 3 08-28-2011 03:24 PM
Recommend a wireless flash trigger please! liukaitc Pentax Camera and Field Accessories 17 08-09-2011 06:21 PM
Best inexpensive Wireless Flash Trigger ? Fred2726 Flashes, Lighting, and Studio 9 09-05-2010 08:33 AM
Wireless flash trigger option for K7 help N155 Pentax DSLR Discussion 28 08-16-2010 06:39 AM
All times are GMT -7. The time now is 06:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
