Newbie - I just purchased this cord
http://www.ebay.ca/itm/220866158781?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 from ebay hoping to use it with my Sigma ef 530 dg st flash and Kx camera, but I can't figure out how to get it to trigger the flash?? Is there something I'm missing? A setting or something that needs to be changed in the camera. The flash works fine when it's on the hot shoe, but with the cable, it won't fire at all. It does recognize that it's plugged in and turns itself on.
If there isn't a way to make this work, can you recommend a different flash or cord that would allow me to try out off-camera flash as inexpensively as possible?
Thanks.
