Originally posted by adwb Is there any flash unit that will keep up with camera in continious shooting mode [HI speed]? mains or battery?
I have found setting a speed gun on minimum output it sort of works but the continious shutter rate slows right down.
It seems unlikly as they all use, I assume, some form of capacitor charging system, but I ask just in case there is something out there
Change your shooting conditions so that you can shoot at lower power. If you need to pop at full power, it will never work unless you have really specialized flashes. Going to lower power will allow the flash to fire several pops at a time.
Using lower power will also decrease your odds of overheating your flash.
