Originally posted by jarnos Frame is exposed also during the opening and closing of shutter. It seems that at least with the Metz flashgun flash duration can be longer than the time shutter is fully open even if using camera's flash sync speed as shutter speed. If the flash is emiting light even after shutter begins to close, you may get uneven exposure. Camera does not know how long it takes to get full flash output and I am not aware of any standard about such maximum time.
the frame cannot be exposed before the opening of the shutter because the flash is synchronised with the leading curtain being fully open, or trailing curtain about to move.
I can believe to some extent the possibility of the flash duration being long, but not with electronic flash.
These deliver all the energy in microseconds.
Years ago I did some testing using a sunpak autozoom 3000, GN30 (meters) at ISO 100. I was actually testing the susceptibility of fibre optic systems to high pulsed ambient light, and my flash was a good reliable source, as it came with a HV power supply and recycled faster than my motor winder. Minimum intensity was just 2 microseconds, and this doubled for each power setting, there were 5 additional, hence the settings were 2, 4, 8, 16, 32, 64 micro seconds.1/180 of a second is 5.6 milliseconds or almost 1000 times longer than maximum flash duration.
It was the old flash bulbs that had flash duration longer than exposure and were essentually (as far as film was concerned), ambient light.
