Since it is getting too cold to be outside much, one of my winter projects is to learn to use my flash. I am using a Metz 48 AF-1 as my starter flash.
Learning how to use the flash today, I wanted to try the wireless option. I set the camera for wireless, and set it as controller as I want the Metz flash to do all the work. I set the flash on a table pointing at the side of a teddy bear as my subject. I learned through reading here that the sensor to receive the signal on the Metz flash is next to the battery door, so I made sure that sensor was pointing toward the camera.
Without moving anything, I got the Metz flash to work properly in wireless mode like this 50% of the time. By having the Metz flash pointing directly at the side of the teddy bear, I could easily tell when it worked properly as I had the left side of the bear bright while I had a heavy shadow on the right side. Only half the time did it work like this - the other 50% of the time the light on the teddy bear was even and underexposed.
So is this the unreliability of wireless P-TTL I have been reading about? This all really doesn't matter much as I am planning on ordering a set of wireless triggers and learning how to control the flash manually - I can see now that doing it manually will allow much more creativity.
