Originally posted by stevelink My question is: Am I using the correct K-5 settings to allow proper flash Sync using the K-5's built-in flash as a "slave"?
How can you use the built-in flash as a "slave"? By definition, a "slave" flash is a unit triggered by another flash. The triggering flash is called a "control" or a "master" flash. The camera's built-in flash, if used, can only be a "control" or a "master."
I now assume you're using the built-in flash as a master.
The slave flashes are the Metz Mecablitz 50 AF-1 and the Sunpak Auto 323 Super. I assume they are triggered by optical slave (can be built-in, I don't know the 50 AF-1 and the term "servo mode").
My question: can the optical triggers ignore the preflash strobe from the K-5's built-in flash? If not, the slave flashes are triggered by the preflash strobe, and fire
before the actual exposure. The light from the slave flashes have no effect on the exposure.
To verify this, run 2 experiments:
1. Have the same setup in front of a mirror, and take a photo of the mirror. It will be obvious whether the flashes fire during exposure.
2. Have the same setup, but set the K-5 in 2 second (self-timer) delay mode. The preflash strobe of the built-in flash will fire 2 seconds before the shutters open. You can tell whether the slave flashes are trigger by the preflash strobe of the built-in flash. If they do, and if they recycle fast enough, they may fire again 2 seconds later during the actual exposure. But if there is no 2 second delay, the slave flashes will not fire during actual exposure because there is not sufficient time to recycle.
