Problem with a Sigma EF-610 DG ST
Hello all,
I have recently started having problems with a Sigma EF-610 DG ST and my K-x. I have the following issues, which may be symptoms of one problem or multiple problems. I don't know, so I am coming here! I usually shoot in Apeture Priority mode.
1) The flash often will not zoom to the correct focal length.
2) The camera doesn't seem to be taking the flash's light output, leaving pictures way overexposed.
The only way I have found to solve the first issue is to turn the camera on after I turned the flash on. It used to not matter. The second issue I have found no solution for. I am quite confused and need some help. Thanks for reading!
