Twarp,
I have tried to us A or Tv mode with my flash also and I could never get consistent results, some shots would have too much ambient and some not enough. So I switched to shooting in M mode and it has made things actually much easier.
With the DA 35mm 2.4 I would start with these setting, assuming you are shooting indoors under tungsten lights.
Apateur - f4 to f5.6, lower if you need more subject isolation
ISO - 200 or 400, you shouldn't need to go higher unless your subject is very far from the flash or it is really dark
Shutter Speed - Variable, I would start at 1/30 and work up from there until you get an ambient balance that you are happy with. The flash should be stopping the motion if the subject looks blurry it is because your shutter was open too long and there was too much ambient exposing your subject after the flash fired.
