Hey Pentaxian, I've got a little question.
I have a few old (read very old) flashed that I would like to use for home studio stuff (OK, mostly for fun). I tested the voltage, and it's pretty high, almost 200v. So, I know I better no try to use it on the camera. That was not the plan anyway.
Question is : Can I use cheap wireless trigger to trigger those type of flashes ? Will the flash burn the wireless receiver?
Also, could I use an optical trigger instead? Would that be safe no matter the voltage of the flash? Here is an example of an optical trigger I would like to try :
optical trigger.
I'm also thinking of using that accessory with an old Vivitar 285, should be fun.
Thank you in advance for your help!
