03-04-2012, 05:17 AM   #1
Twarp's Avatar
AF-360FGZ on Program A/Super Program
According to the manual of the mentioned flash, TTL is not supported. However, when I put it on my Super A set to P with the aperture on automatic and the flash to P-TTL, it switches the camera to its 1/125s flash-sync speed, the aperture to 5.6 and shows the lightning symbol when the flash is charged. The lens used is the A 50/1.7.
These are exactly the same values as the old and dedicated AF280T in TTL-mode produces in the viewfinder of the camera. So it looks like the AF-360FGZ behaves like the old TTL after all. No indications that something goes wrong. Anyway I didn't notice any preflash as the camera wouldn't know what to do with that.
I made some identical pics with both flash units but it will take a while before the film gets back from the lab.
Can anyone comment on the expected results?
03-04-2012, 07:07 AM   #2
I have that flash too... but my sycs at 1/180 (K2000).
03-04-2012, 07:23 AM   #3
aurele's Avatar
the flash AF360 is aroung 30GN with a 50mm, and the 280 is 28GN with 28mm lens.
They are both, more or less, the same power. This explain i guess why they both set the same parameters for the picture in P mode.
03-05-2012, 09:31 AM   #4
Twarp's Avatar
I didn't think of it in this way, in my opinion the 280 is a fair amount weaker than the 360... But setting these parameters means that communication takes place between camera, lens and flash. The question is, does the flash behave as (a) TTL-compatible (P-TTL) while each and everyone states that TTL is not supported?
03-05-2012, 02:51 PM   #5
I think TTL is actually in the firmware, but Pentax just won't provide technical support.
03-05-2012, 03:08 PM   #6
Twarp's Avatar
Well, I can live with that! So not providing support is something else as the feature not working as defined.
That means that I can travel with only one flash instead of two when taking the Super A along with the digital one.
But I'll wait for the testresults to confirm...
BTW, the Program A does not support TTL, the Super A does.
03-24-2012, 06:11 AM   #7
Twarp's Avatar
Results comparing AF280T and AF-360FGZ in TTL-mode on a Super A: identical!
Here are the (unprocessed) scanned results from the AF280T, no need to double them:
Straight flash
45 degrees bounce
90 degrees bounce
03-25-2012, 10:23 AM   #8
Well, I don't know about your manual, but I just checked my AF360FGZ Operating Manual. On page 26 & 27 there is a full write up of using the AF360FGZ in TTL mode with various cameras, including the Super A. Also check out the chart on pages 19 - 21. TTL is a function of the camera and this flash is compatable.
03-25-2012, 10:44 AM - 1 Like   #9
Twarp's Avatar
Crap, you are right! I found the table on a different page in the Dutch manual, I read it once but is easy to miss. Usually the English version is preferred but this was a single booklet, the English version was combined with French, German and Italian and maybe even Spanish so I put it in the box. Since I don't have (had) an ist D, ist DS or ist DS2 I just skipped any passage relating to them and indeed there it is mentioned that TTL is displayed on the LCD.
But I assure you that any shop I investigated, also in online specs given, state that only P-TTL is supported. It kind of feel a bit pissed now for not reading the manual at least TWICE.
Anyway, my little test confirms what is in the manual after all
08-10-2018, 07:18 PM   #10
QuoteOriginally posted by Twarp Quote
Yes, the AF-360FGZ is quite an amazing flash. On my oldest Pentax bodies (at least with hot shoes) it can work in Auto mode. On the later TTL bodies (like my Super Program and my PZ-1P) it automatically goes into TTL mode. On the later film bodies that support P-TTL (like my ZX-L and MZ-S), it does that mode. Finally, it works just fine on my digital K-70 in P-TTL. Quite neat.
af-360fgz, aperture, camera, flash, lighting, photo studio, program, strobist, ttl
For Sale - Sold: Six Pentax Film Bodies (Z-1, PZ-1, SF1n, P3n, Super Program, Super ME) dgaies Sold Items 5 06-23-2011 01:45 PM
For Sale - Sold: Pentax-A 50mm f1.7 and Super Program (Super A) body EXC. (Worldwide) cheekygeek Sold Items 7 05-10-2011 02:55 PM
Comparison Super Program vs. AE-1 Program pyra_ohms Pentax Film SLR Discussion 12 10-20-2010 08:50 AM
Help with Super Program/Program A and TTL Flash tendim Pentax Film SLR Discussion 9 09-09-2009 07:01 PM
All times are GMT -7. The time now is 03:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
