You can make a "quick release" for your flash.
1. Obtain a Raynox Universal Adapter, the one that comes with the Raynox DCR-250 or DRC-150. If you don't have it, you can buy the
Raynox Universal Adapter for Raynox CM-2000 Macro Lens for about $10 + shipping. Do NOT buy the
Raynox Universal Adapter for Raynox CM-3500 Macro Lens because its opening is very small (37mm). Use epoxy to glue a 67-58mm step down ring to the adapter. Note that the "fat" face of the step down ring is against the Raynox adapter. You need as much gluing surface as possible.
2. Attach a 58mm adapter ring (essentially a 58-52mm step down ring) to the flash:
3. Screw the flash and the Raynox adapter together:
Bingo! Now the flash can be instantly attached to/detached from any lens with filter thread diameter from 52mm to 67mm. This is the flash attached to a Tamron 90mm macro lens (55mm filter thread):
Of course you'll have to watch out for vignetting because the opening of the Raynox adapter is only 43mm. But I don't have vignetting problem with my Tamron 90mm and Sigma 50mm macro lenses.
You can choose to glue, say, a 62-52mm step down ring to the Raynox adapter (step 1), then you can just attach the Sunpak flash to the Raynox adapter (the Sunpak flash has 52mm diameter). But then the Raynox adapter is "dedicated" to the Sunpak flash because it can't accommodate the Raynox lens any more.
If you use a 67-58mm (a 62-58mm will also do, but you don't have as much gluing surface), the Raynox adapter can still be used for the Raynox lens:
Do not attempt to attach the Raynox adapter to lens with filter thread smaller than 52mm. You may break the "ears" of the adapter.
