03-13-2012, 08:48 AM   #16
baro-nite's Avatar
QuoteOriginally posted by tuggie76 Quote
There's also a 360 as a rim light, probably low and behind the flower?
Oh damn, just realized I have been looking at a different pic, making me sound even more deluded than I usually do. Yep, the 540 is low left, pointing at the leaves, 360 side right, ringflash fill. Of course the caption tells us most of that.
03-13-2012, 11:31 AM   #17
Orchid
I took this yesterday using as lose an approximation as I could of the technique used, not quite so good though!
Tuggie76
03-13-2012, 01:13 PM   #18
stormtech's Avatar
Thanks to all the input from everyone - I just ordered the ring flash.
And I couldn't help myself at that point and ordered an AF540 flash to go along with it.
Now I am broke once again, but looking forward to all the fun I will have with these.
03-13-2012, 03:11 PM   #19
jac
We are delighted to have contributed to your FBA (???) and your recent insolvency. If you would like to discuss lenses at a later date, A*200 macro, APO Lanthar 125 or some such, we would be only to pleased to contribute to your move to complete bankruptcy through LBA :-)
03-13-2012, 04:26 PM   #20
Digitalis's Avatar
QuoteOriginally posted by baro-nite Quote
You are pretty close, but this is how I actually did it : the AF540 was fitted with a sto-fen diffuser and set to 1/8 power and elevated a foot above the rose using a flash stand and positioned one foot behind and to the right of the rose bloom*, the AF360 was to the lower left and placed on the ground and set to 1/2th power, so there is a near 4 stop range between the two flash units, and I used the ring-flash at 1/4th power to reduce the overall contrast in the scene - so I could locally adjust the contrast in Lightroom to taste.
*the shadow on the leaf in the lower right portion of the frame is a dead give away. And if you look at the stem you get a hint of the power ratio I used between the two flash units.
03-13-2012, 06:08 PM   #21
baro-nite's Avatar
If you read it aright! I puzzled over that shadow but got it exactly wrong. Think I was confused by some of the shadows on the blossom. Thanks for the info, very instructive.
03-13-2012, 06:50 PM   #22
Digitalis's Avatar
no problems, learning how to de-construct a flash photograph is an incredibly useful skill, and it is certainly a skill worth learning. I have always had a knack for doing it, for me the most important thing is paying attention to the shadows and the highlights. Because the shadows tell you more than just about where the light is in the scene, but what light shaping tools were used. The Highlights are more of a directional cue, they indicate the position of the light and they also can help indicate if diffusing light modifiers were used.
03-13-2012, 07:01 PM   #23
Thanks cobber, now to find a red rose and give it a go!!!!!!!
Tuggie76
control, flash, flowers, images, intensity, light, lighting, pentax, photo studio, strobist
Ring Flashes: Pentax AF160FC vs Metz 15 MS-1 Clinton Flashes, Lighting, and Studio 37 06-13-2013 02:10 PM
AF160FC ring flash rvannatta Flashes, Lighting, and Studio 3 10-09-2011 12:57 AM
Pentax AF160FC Auto Macro Ring Flash Fl_Gulfer Pentax K-5 & K-5 II 4 01-17-2011 08:44 AM
Macro Trying out my new Tamron SP AF 90mm F2.8 and Pentax AF160FC ring flash nirudha Post Your Photos! 5 05-25-2010 10:46 PM
All times are GMT -7. The time now is 03:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
