Originally posted by Jodokast96 You can't do high-speed sync with the built in flash. To use HSS, you have to choices. Mounting the 540 to the camera will allow it. Or if you need wireless, you have to get a second 540 or 360 and mount one on the camera.
There is one other option which is a TTL cord of some sort. But yes, this is true though it seems woefully (almost intentionally) undocumented.
The pop-up flash, the hotshoe, and the PC socket all turn off above 1/180th if the camera cannot detect a HSS flash. There is no way to get a sync signal to a slave flash from a Pentax camera without having a HSS flash somehow attached to the camera's hotshoe at speeds over 1/180th. None.
Please accept my condolences and know that you are not alone in your frustration.
