Originally posted by littledrawe I am wondering about specific things I need to do to get these shots right so they look good when printed, they will be relatively small with multiple pictures on each page I've heard that I need a high ISO for printing like this but I'm not sure, if so why?
There's no reason why, because someone has their terms messed up. They probably mean you need a "high resolution" for printing (typically 300 dpi) which, if you're using a K-7, is no problem for portraits or even crops.
But this is for a High School playbill? Check first that it will be printed in color (!), then be sure you use a consistent colorspace (Adobe RGB in camera, in processing, and in the RGB TIFFs you hand off) and that your monitor is calibrated, as much as you can do it. And if it is in color, it will probably be digital prints (not offset), so imagine that your images will print darker and more contrasty than you see on screen.
Next, treat it like a professional photo shoot like you'd do for Broadway. I'd suggest getting to the stage way earlier than the "talent" does, but ask that the lighting manager be there to man the board, and use a stand-in (stage managers are great for this) to get your headshot lighting right. Do the headshots first, of course, and if they are in-costume do a head/shoulders portrait (no sense wasting that finery). Maybe ask if the "house lights" can be turned on, as they will fill almost everything.
Then coordinate the staging of the group shot with the director (having some seated, some in the scowl of their character, etc.) and shoot, shoot, shoot. Most likely your flash won't be enough for the group shot, except to lighten shadows. Rely on the stage lights and maybe bracket exposures to get the set properly lit (don't use the brackets for the people, they blink or move).
Finally, since it's a professional shoot (no matter who for, or how much $), show up early, be smooth and efficient, and tell people what to do and how to pose. That's your job. Their job is to listen and look pretty.
