--------------------------------------------------------------------Review Part------------------------------------------------------------
Finally got the item, took nearly 3 weeks for it to arrive.
I guess it's reasonable since it is shipping from China.
This is the one I got, great price and the company seems big and reliable.
Nanguan Lambency Flash Diffuser P4 for Canon 580EXII 580EX 550EX - DinoDirect.com
Here starts the review, all shots are direct out of camera.
K5 / pentax-F 35-70mm / yongnuo 560 ii
Jpg format, only resized to 800px width.
All neutral effect - 0 contrast, saturation, sharpness, etc.
Fixed white balance - day light WB.
Flash is about 1.5 meter away from the scene.
Please excuse the slight changing of exposure of each photo, I am still new to flash :/
This is the product.
The cup itself looks a little blue-greenish.
Also comes with a white cap and an orange cap.
It even comes with some extra stuff like post cards and a bottle opener, not bad
Here is the set up scene.
The shot is taken w/o flash, only window light, and a longer exposure. Here is a shot of the flash working.
It is pointed to the ceiling.
As you can see, it shots a bean of light directly up, the scene hardly gets any light.
Here is the flash with the cup mounted on.
The scene gets some light from the diffuser.
But most of the light are still shooting up the ceiling.
Here is the flash with the cup, and the white cap mounted on.
The light is now much more diffused.
The scene is getting more light and the diffuser itself looks & acts like a light bulb.
On-camera flash directly shooting the scene.
As everyone expected, harsh shadow, artificial looking.
The WB also looks a bit on the cold side.
On-camera flash with the cup directly shooting the scene.
Can't tell much a difference from the above, since the flash is still shooting a bean of light to the scene.
On-camera flash with the cup and the white cap, shooting directly to the scene.
The shadow is slightly softer, take note on the shadow on the pillow that cast by the doll.
But generally speaking, still not a big difference from the above
On-camera flash, no cup, ceiling bounce.
Much better looking image. It appears a bit warm because the ceiling is a yellowish color.
On-camera flash with cup, ceiling bounce.
Sorry this one is a bit under exposure.
And I am not finding a big difference from the one above, except the cooler color (probably because the color of the cup)
On-camera flash with cup and white cap, ceiling bounce.
Surprisingly, this set up brings some shadow to the scene.
Notice the shadow on the pillow that cast by the doll.
It is probably because the "light bulb" is spreading energy around it.
Also the light is more evenly lifted, take note on the doll's face compare with the 2 shots above.
On-camera flash, shooting to the left of the scene, wall bounce.
Similar to ceiling bounce, not much to say about it.
Notice that the color gets really warm. Color is hard to control if you don't have a white wall.
On-camera flash with cup and white cap, shooting to the left, wall bounce.
Again same as last case, the "light bulb" gives some shadow to the scene.
That also shows the diffuser is working and giving off light to every direction.
On-camera flash with cup and orange cup.
As expected, it makes the scene very warm.
It may be use to create interesting visual effect if use it right.
Also can be use as color gel.
Off-camera flash on the left side, shooting directly to the scene.
Very very harsh shadow and blinding lights.
That's all to say about it.
Off-camera flash with cup and white cap to the left, shooting directly.
Generally softer shadows, definitely some improvements.
Off-camera flash on the left side, ceiling bounce.
Basically the same as On-camera ceiling bounce.
Off-camera flash with cup and white cap to the left, ceiling bounce.
The light is more even lifted, and the flash brings shadow to the objects.
Base on all these experiments, I came up with some conclusion.
1. the diffuser works more like a light bulb instead of diffuser.
2. putting the cup on but with no cap, won't give you a very big difference.
3. with the cup and cap on, base on distance it will bring shadow to the objects even it's just ceiling bounce.
4. it does soften the shadow a little bit, spreading light in a circular motion and lift the scene more evenly.
When shooting indoor, it won't bring a huge improvement if you already have a low and white ceiling.
However, when shooing in situations that you have no way to bounce (outdoor, high ceiling, etc) but to shot directly at the object, it will definitely be a helper.
I will test it on outdoor fill flash when I have a chance.
Please leave me any of your thought about this review.
Thanks for reading.
--------------------------------------------------------------------Old Post----------------------------------------------------------------
Got my yougnuo yn-560 flash around a month ago, everything about the flash is awesome, especially using it off camera.
However, I do need to find a way around to fix the very artificial shadow.
So I did a lot of research on different types of diffusers, some are extremely expensive while others are very cheap.
And in general cup shape diffuser seems gives a better price/performance ratio, I ordered one.
By looking at this video I know the yongnuo and the canon have the same design, so the cup should also fit the flash fine.
I will post a detail review after I got the item, hopefully it will do some improvement on the photos.
