Originally posted by robert I never really considered this but but on my old metz 32 mz3, when you set the focal length option do you have to compensate for the camera being digital as opposed to 35 mm?
This is a good question, and shows you are thinking about what you are doing.
The focal length setting is used to focus the light to cover the field of view (FOV) of the lens. As a result, switching to digital format, the flash will actually light up more than you need. Not a bad thing, but it uses more power to do this, so it will impact extreme range shots because when it focuses the light the guide number goes up, and also battery life, so if you are shooting a lot it makes sense to adjust these for your format.
