I've been reading the K-5 Manual on how to set up the built in flash in wireless mode when using an external flash unit in combination with the built-in flash .
so here is how I did it,
Turn on the power to K-5 set the camera to Wireless Flash. Press the four-way controller ( Down arrow ) then flash mode screen appears.select Wireless mode.
set the power switch on my AF-360fgz external flash unit to WIRELESS and set the Wireless mode on the external AF-360fgz flash unit to SLAVE.
To set up the channel for wireless comms between the external flash unit and built-in flash I placed the external flash unit on the camera hotshoe locked it in and switched the power back on to
Wiresless for AF-360fgz external flash unit and on then turned on the power to the K-5.
pressed the shutter half way . and now apparently the external flash and the camera are on the same Default channel CH1. I'm not sure if this step needs to be repeated everytime user needs to
use the external flash unit in wireless with the camera ? someone else can confirm this. or if the default is set to CH.1 may be this step is not required . it may be only required if another channel is to
be selected ?
Detattach the external flash from the camera hot shoe and placed it where ever you feel is suitable to create the effect your after , I placed my External Flash unit behind the subject some where
underneath the lace curtain to see what effects I can create
I like the cool effects that i can create with my K-5 built in flash and the external AF-360fgz Flash , I think same process applied for AF-540fgz
Anyhow here is some sample shots , I hope this would help others to set up their camera to operate in Wireless Flash mode.
me iz very happy
