I've just tried out these two guns and thought it may be useful to highlight the fundamental differences between them, as they are both P-TTL compatible.
It may be easier to state what the 48 doesn't do, rather than make a list of comparisons. It is not intended as a comprehensive detailed list, just a highlight of the major functional differences.
- No Wireless support [Not so. Apologies, my error - corrected in a later post. See #6 https://www.pentaxforums.com/forums/155760-post6.html ]
- No A (Auto) mode, it has no built-in sensor, it relies on the camera metering.
- No secondary (infill) flash
- Lower power output (GN of 48 rather than 58)
Summarising, the 48 AF-1 is just a simple P-TTL external flash with tilt & swivel, it's not nearly as capable as the Pentax AF 360 which has wireless/slave support and
A (Auto) mode, the only downside of the 360 is the lack of a swivel head and slightly lower power, but you can detach the 360 and use the pop-up as a controller/infill and use the 360, either in your hand, or on an adjustable mount/support.
Both units feature HSS. In comparison, the 58 AF-1 is a very capable and comprehensive flash, easily comparable to the Pentax AF 540 (in fact, maybe even slightly more capable). It supports all modes and has it's own built-in infill flash (switchable). It has full wireless support, including HSS wireless when used with another controller/slave that also has HSS wireless (Note that the K10D pop-up flash doesn't have HSS, whereas the istD does). It works seamlessly in wireless in conjunction with any Pentax wireless P-TTL gun. The 58 AF-1 will also support wireless
A (Auto) with two (or more) 58 AF-1 guns, I'm not sure if the Pentax guns will do this, I believe that wireless is only supported in P-TTL mode.
I haven't tried the latest Sigma EF-530 DG Super, only the previous EF 500 DG Super, which if fitted with the latest chip upgrade worked well enough including wireless, although like the Metz 48 AF-1 it doesn't have it's own metering sensor allowing
A (Auto) mode and the constructional quality was not up to the same standard as the Metz or Pentax guns, but it certainly represents decent value for money.
As I'm currently looking at upgrading my flash (an old Metz 54 MZ-3) and I frequently use
A (Auto) mode (to eliminate pre-flash blinkies), my choice in order of preference would be (I've ignored other physical factors such as size etc.):
Metz 58 AF-1, Pentax AF 540, Pentax AF 360, Sigma EF 530 DG Super, Metz 48 AF-1
I hope this is some use to those considering buying a new P-TTL capable flashgun.
Cheers
Reason: Correction about 48 AF-1 wireless
