Originally posted by nicholek Ok I am using manual mode and I understand the iso, ss, fstop enough to use it. But my question is will the camera and flash not communicate and tell me what it will be with the flash on? How do you know how to get a correct setting if the camera always says one thing but when you take the picture the flash makes it different than what the camera said it would be?
The first thing to learn about the flash photography: shutter speed has no effect on exposure resulting in flash output (e.g. reflected light from the flash). Technical limit is flash sync speed, 1/180 with *istDS and i believe K100D and K10D. Only aperture has effect and you regulate the brightness of the scene with the aperture in simple flashes, or P-TTL you regulate the "output range" a flash can automatically adjust output for.
To understand how it works do the following: Set your camera to "M" mode and set shutter speed at 1/180 (with flash turned on you can not go over 1/180 anyway if not in HS mode, forget about this for now). Make sure the flash is in P-TTL mode. Tap shutter release button to wake-up you camera (metering goes to sleep mode after 10 seconds) and the distance scale will appear showing you that for a given aperture P-TTL system can preflash, meter through the lens, and adjust the flash output to cover distance indicated by the bar on the scale. Try changing the aperture and see how distance scale changes. Don't forget to have metering active or scale will not appear. Once you are happy with the range, start shooting and don't worry about anything for now.
Note: This applies to normal flash head position. If you twist/tilt flash head distance scale disappears. This is because camera can not possibly not know from what surface light will bounce (distance and color). For twist/tilt open up aperture by one to two stops for bounce from close white walls (regular room). More for farther and/or darker walls.
This is only a start, there is much more to it but for now understand the relationship between aperture, P-TTL range, and automatic P-TTL flash output adjustment.
Once you get comfortable with the basics you can learn advanced techniques with slower shutter speeds to balance ambient and flash light, on-flash output compensation, manual flash mode, high speed (HS) mode, effect of ISO setting, and more.
