03-16-2013, 06:44 PM   #16
Otis Memorial Pentaxian
RobG's Avatar
QuoteOriginally posted by Pirate Quote
I haven't checked to see if the JY-670 has TTL metering like the Delta, but if it does, then for the price, it's a bit of a bargain. The Delta is available from Foto-Tip via evilBay.
Please refer to my other post about the Viltrox. Bob says his works with his K5, but mine doesn't work properly with my K5iis. It does work with the K7 and K200 however. It is a manual flash and doesn't provide TTL metering; the hotshoe only has two connections unlike my Sigma TTL flash which has four.
08-09-2013, 01:58 AM - 1 Like   #17
McBrian's Avatar
Apologies for resurrecting this thread but I thought I would add a little info that may be helpful.
I’ve recently taken delivery of one of these and can concur with Rob that is does not work with the K5IIs, it will fire the first time the shutter is activated but won’t fire again, you have to dismount it or switch both off and on to get it to fire again.
However it works a treat with a K30 and that suits me fine as my K30 is setup as my macro body with a Katzeye split screen (uses the same screen as a K5, K5II/IIs). The unit is easy to use and is reasonably well built, and as has been mentioned it is a conventional flash, not LED’s (it has 2 LEDs for focus aid), has full adjustment from 1:1 to 1:128 in full stops or 1/3 stops, left or right tubes or a contrast ratio down to 1:8 either side, no P-TTL, it's manual all the way.
I hope this is helpful.
Regards
Brian
11-01-2013, 05:52 AM   #18
McBrian's Avatar
A quick updated, works great with the K3
11-01-2013, 06:43 AM   #19
RockvilleBob's Avatar
Auto Focus
QuoteOriginally posted by McBrian Quote
Have you had a chance to look at the K-3 auto focus? If so how does it work? Thanks
11-01-2013, 09:02 PM   #20
RobG's Avatar
Interesting! I'll have to try it again with the K5iis after the latest firmware update, but I doubt that there will ever be a change. Tried it and still only fires once with firmware 1.06.
11-02-2013, 04:33 AM   #21
Papa Lazarou's Avatar
Well that's good to know. Need to try it on the K-3 now, was hopeless on the IIs.
flash, jy-670, lighting, photo studio, strobist, viltrox, viltrox jy-670
For Sale - Sold: AF280T Bounce Flash w/adaptors & AF080C Ring Flash (US/UK/CAN/AUS) MJL Sold Items 3 02-07-2011 10:19 PM
Alien Bee Flash Unit or Ring Flash Hey Elwood Photographic Technique 2 06-24-2010 07:37 AM
Ring flash / ring light for macro tcom Flashes, Lighting, and Studio 5 07-28-2007 10:26 AM
Opinions: Ring light or Ring Flash Peter Zack Flashes, Lighting, and Studio 8 07-14-2007 07:44 PM
All times are GMT -7. The time now is 01:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
