Originally posted by eccs19 The first image was actually at a lower ISO, and I had to bump the exposure in post by over 2 stops, that was the ISO I was hoping I could use, but it just didn't seem to balance out till I got to 1600. I can't believe that I needed to be at 1600 for the flash to have enough power. I will definately have to try manual next time just to see. This will tell me right away if the flash has enough power.
Just remember.
Distance = (ISO/100)^.5 x GN / Fnumber
Because GN is based upon 100 ISO at F1.0
If I take the numbers you posted and convert them, you were shooting from 5-15 meters, at F3.5 and ISO1600
A ISO 1600 the GN is 200 assuming the 50 in the flash model stands for the GN (4xthe published number) shooting at F3.5 largely negates that so your maximum working distance would be 50 meters. You should be OK. Even at that aperture and ISO800 you should be within your distance estimate, but note, distance can be tricky to guess
