I recently bought the AF540fgz because I plan to do wireless highspeed at some point, when I can afford another AF540, which I was told this flash can do... and it also being the only flash for Pentax that can do that apparently. I wonder if it is even worth it/doable when shooting mountain bike races?
Anway, it seemed to work as expected, but the flash does at times make a loud mechanical stuttering sound, as if it was rapidly adjusting focus, is this normal?
Furthermore, when using the trailing curtain setting, the flash did not seem to fire at all, only after setting the camera itself to trailing curtain in the K-5's flash option menu, did it seem to work correctly, can that really be right? My Metz 48AF does not need for the camera to be set to trailing curtain, so that was a bit odd to me.
The AF540 seems like a decent flash, but it sure does take some getting used to, when it constantly forgets the power compensation. Kept burning out colour every now and then because it...
The rest of the time the pictures did seem to turn out well (K-5 + DA* 16-50 + AF540fgz, on trailing curtain)
