07-26-2012, 07:36 AM   #1
LFLee's Avatar
How big a reflector is enough?
Hi all,
I wanted to get a reflector, and narrow down to a diameter of 43" and a 32" one.
I wonder if the 32" one is sufficient, say, for two person head shots?
I am hoping to improve lighting in outdoor situations.
43" one:
http://www.amazon.com/gp/product/B002ZIMEMW/ref=ox_sc_act_title_10?ie=UTF8&smid=AL7LHK6Q9LVTS
32" one:
Amazon.com: NEEWER
Would like to hear your advise. Much Thanks!
07-26-2012, 08:26 AM   #2
reivax's Avatar
I own those exact two. I find that the 32" works really well for on person. I don't know if it will work really well for two people (maybe if they were really close).
The 43" is probably a little better for two people. You will probably have to play around with it and I don't think the two people will be able to be too far away from each other.
One thing I do want to point out is the 32" and the 43" don't really sound to be very different in size, but they are. The 43" is a lot bigger.
If you really want to do two person head shots, the 32" probably won't be enough in most situations. The 43" might work.
07-26-2012, 09:04 AM   #3
LFLee's Avatar
QuoteOriginally posted by reivax Quote
Much thanks!!
Can you tell me when they are folded, what is their respective diameter? the 43" one said to be folded into 13" while the 32" one said to be 15", which don't quite make sense. Would you comment of the portability (like keeping them in camera bag) of these two (which one is more convenient)?
If you have a picture of these two relative to a Pentax Camera (might be asking too much).....
07-26-2012, 09:08 AM   #4
JohnBee's Avatar
I have many reflectors, one which is aprox. 5'
I usually use it indoors to work with taller portraits.
When I collapse it, its quite small. Something around 20" in dia.
I have a seperate bag for my reflectors but I'd have no issues stuffing them(including my big one) in my main pack if I had to. But the stands require a separate bag.
07-26-2012, 10:30 AM   #5
reivax's Avatar
The 32" is about 13" when folded. The 43" is about 15" (maybe 16"). That obviously makes the 32" more portable. If I had bought the 43" before the 32" I probably would have never bought the 32". There's not really that much of a difference to make one a lot more portable than the other, but the 43" gives you much more of a surface to work with.
I've usually just clipped one or the other to my camera bag, I don't think they will fit inside of a camera bag without taking up too much space for other things.
07-27-2012, 08:40 AM   #6
LFLee's Avatar
Thanks guys! really helpful. will get the 42 inch one. =)
07-27-2012, 05:47 PM - 1 Like   #7
FWIW - I've often wished for a larger reflector. Can't recall ever wishing for a smaller one. But that's just me.
07-29-2012, 06:02 AM - 1 Like   #8
omega leader's Avatar
Get as Big as Possible
I have a 32" one as I decided it fits nicely folded in my bag. However, shooting with other photographers I've discovered a much bigger one is better, it works better to block the sun, it can reflect the light further allowing it to stay out of the shot if your using a wide angle, and it creates a more even light.
Get a bigger one, if I couldn't borrow one, I'd have bought my own in a heart beat.
08-01-2012, 07:59 AM   #9
LFLee's Avatar
thanks jford and omega leader. =)
08-01-2012, 12:20 PM   #10
Moderator PEG Judges
Kerrowdown's Avatar
I can recommend getting a couple of these types which I use for most of my jobs Collapsible Photo Studio 5-in-1 Reflector 100cm x 150cm | eBay
The five in one, has options of white, black, silver, gold and translucent to diffuse light and all at 40" x 60" size. You can always move the reflector further back for less bold effects. It still folds down into 20" diameter zipped case when not in use, ideal to carry about.
08-04-2012, 01:07 PM   #11
QuoteOriginally posted by JohnBee Quote
Hi John, could you elaborate on what bag you have to hold your reflectors?
Thanks
Jim
08-16-2012, 11:00 AM   #12
LFLee's Avatar
Got my 43' reflector .... hm... definitely not the size you can stuff in your regular camera bag. =)
Will see how this works out.
Lee
flash, lighting, photo studio, reflector, strobist
Adorama Portable Reflector Bracket 22-52" Cregar Photographic Technique 5 06-21-2011 01:03 AM
Small reflector ideas? grainbelt Pentax Camera and Field Accessories 14 01-01-2011 11:04 AM
do I need a reflector? momtographer Pentax Camera and Field Accessories 8 05-23-2008 07:41 AM
All times are GMT -7. The time now is 07:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
