Originally posted by mtansley You could also mount the flash on a hotshoe adapter that only has the main trigger (center) connector on it. This would still allow the flash to be used manually (does your flash have an 'A' mode?) or in 'A' mode if possible.
I sometimes do this with my Metz 58 AF-2 when I want to disable the automation between the camera and flash.
Mtansley wins the prize!!!!!!!!!
I put a Cactus radio wireless unit on the hotshoe, which also features a hotshoe center connector on it's top side, to do the same thing that mtansely suggested. I then put on the manual only hotshoe, a Metz 48 that normally does pttl. It worked perfectly and allowed the green focusing light of the K5 to operate while eliminating the red light of the flash.
I then tried the fix of putting the camera in AF-C mode, but with the flash connected directly to the camera. Unfortunately it not only turned off the red assist light from the flash, but also the green assist light from the camera - bummer.
I also experimented with my lens hood which often interfers with the green focus light. Removing the hood from the lens(a pentax 17-70), allowed the green light to shine out without any obstruction from the lens - no crescent shaped light this time.
Those hotshoe adapters can be had pretty cheaply from ebay i think.
