Bingo! That was the issue ... not sure how I missed that nugget of information, nor how I managed to get it into that mode to begin with. Many thanks!
Originally posted by steve1307 Are you in wireles Slave mode 1 "SL1" (this is the normal one where wireless P-TTL works) or are you in slave mode 2 "SL2" (which is just a manual strobe setting for a basic slave flash).
page 52 of the manual shows how to change it.
Slide the switch on the right up. Press the button marked LIGHT for more than 2 seconds. It will swap from SL1 to SL2 or vice versa.
For P-TTL function in wireless you need SL1.
