Page 65 of AF-540's manual (
http://www.pentax.jp/english/support/man-pdf/acc_st_af540fgz.pdf) shows that HSS is not available in Manual Flash photography? Why can't I set the flash output to 1/32 and use it in HSS mode? Why would that be the case? Why is Pentax limiting this?
I see one explanation. flash output power really becomes dependent on the shutter speed as faster the shutter speed, the less flash output will be used for exposure. But that could just be a simple note in the manual saying that 1/32 or 1/4 don't correspond to the same values in other standard sync modes.
I also notice that if the camera (checked on both K-20d & K-5) mode is in
M, the body doesn't allow you to set a faster shutter speed than 1/180. if the attached 540 is in HSS mode. Again, I fail to understand why there are "Automatic" limitations like this when in Manual mode? Isn't Manual the mode for ultimate freedom?
Nothing that frustrates me but I am curious on this design limitation...
