Originally posted by saggsy I hadn't thought about using the aperture.
Make ISO your go-to variable if you're already at full power, especially since you have a K-5. Use aperture only if you start climbing into ISO 6400. The hierarchy should look like this power output > ISO > aperture. Shutter speed won't affect your flash's exposure, but it will affect the ambient exposure.
Originally posted by saggsy Not being experienced flash, and I've only used it on still subjects, I expose for the ambient light then set the flash to full or half and just keep moving it forward/back til it's correct. I was hoping to use similar, but adjusting flash power rather than distance. I would hope I'd pretty quickly know which flash power to be using.
Well you will have a distance that is most comfortable for you, what I'm suggesting is learn what flash power setting gives you proper exposure at that distance/aperture/ISO combination. Make that your reference point. Then it won't matter what color clothing your subject is wearing, or the dominant color of the background, your exposures will just be right. If most of your shots are taken at 3 or 4 or 10 meters from your subject, then that is the working distance that you want to know inside and out. When you can fill in the blanks in the following statement, you will have this manual flash thing nailed.
"I like to be _____ meters from my subject. I like to shoot at f/_____, and ISO _____, so the power setting that will yield correct exposure every time is 1/___ power."
That's it, it's just that simple. The math is just easy halving or doubling from there.
