09-12-2012, 10:18 AM   #16
Neo_'s Avatar
QuoteOriginally posted by Anvh Quote
When you start working off flash with multiple flashes you just need to do everything manual.
Not if your name is Joe McNally
Actually he also uses optical slave trigger at insane distances, you mere mortals try that...
09-12-2012, 10:43 AM   #17
Anvh's Avatar
Yeah some people do it but you have little idea what the flash actually do so it gets over your head and complicated quite quickly.
Besides all normal studio flashes are manual anyway and i've never hear anyone complain about that
09-12-2012, 11:18 AM   #18
Neo_'s Avatar
I also use full manual mode and besides that Pentax TTL flash management is just not up to the best and sometimes it exposes in arbitrary ways especially in wireless mode, besides that in a studio situation there is no way you'll get the "correct exposure" in any Auto mode nor in camera or on strobe
12-06-2019, 05:52 PM   #19
Hello, would anyone know why the wireless flash option would be disabled on my K5?
When pressing the flash button on my 4-way pad, only the first two flash options can be selected whereas the last two are disabled.
12-06-2019, 09:23 PM   #20
Kobie's Avatar
Is there a "flash in wireless mode" or similar option within your actual "menu" options somewhere? Most likely in the "C" menu area to the right side.
If so, you may just have it turned off.
I don't have a K-5 so I don't know what the specific options are, but I think the wireless modes are for wireless (infrared) shutter release.
Try turning on wireless shutter release and see if those options come on.
I'm not near my K-3 so I can't double check my settings right now, but I would imagine they'd be similar.
I can check when I get home though and see what setting (if any) disables the wireless flash option.
12-06-2019, 10:52 PM   #21
Kobie's Avatar
QuoteOriginally posted by Kobie Quote
I figured it out.
Wireless flash will be disabled for the following shooting modes...
1) All mirror lockup modes.
2) 3 second wireless remote shooting.
12-07-2019, 07:36 AM   #22
I figured it out.
Thanks for your response, but I donít think itís that. Iím in normal drive mode. I went through the manual and it might be the lens. Apparently, if your lens doesnít have an A mode, you canít use wireless flash. Iíll try another lens and report.
12-07-2019, 05:52 PM - 1 Like   #23
The problem was the manual lens with no A setting. Once I added a lens with the A setting and set it on A, I was able to select wireless flash.
flash, k5, lighting, photo studio, strobist
Kr wireless wont flash without built in flash selected Phil_jman Pentax K-r 14 01-11-2014 03:47 PM
Using Built in Flash in Wireless mode with External Flash i.e AF-360fgz disco_owner Flashes, Lighting, and Studio 7 05-16-2012 07:41 AM
Manual flash learning curve Yukoner777 Troubleshooting and Beginner Help 29 01-12-2011 02:43 PM
Wireless Flash Triggers for Pentax K20D & 540FGZ Flash? veezchick Ask B&H Photo! 2 11-29-2010 04:07 PM
Learning Flash/Lighting/Strobe atk_designs Flashes, Lighting, and Studio 4 12-22-2009 05:45 PM
All times are GMT -7. The time now is 11:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
