Originally posted by amoringello Just be aware that the pop-up flash does flash for the control to tell the remote flash to fire.
If set "Flash in Wireless Mode" to Off, the pop-up fires very dimly.
In most cases this is too dim to affect the photo.... "most"...
If you are very close to the subject, the pp-up flash will affect the exposure.
Also, reflective surfaces (windows, mirrors, christmas ornaments) will show the pop-up flash firing.
One more thing... very bright sunlight might overpower the pop-up trigger control if you're not facing the receiver directly.
My opinion is that I would not spend the money or effort on other options at the start unless you feel this is going to be an issue you cannot avoid.
If you are hand holding your flash you probably wont have any issue triggering it with the on board flash. If you put it on a lightstand, etc, then move around, change your distance...the possibility of misfire or no trigger becomes bigger. If you are doing it for fun, no biggy - if you have a subject waiting for you to take a picture, a flash not firing is just annoying.
The good thing about these radio triggers is that they work with any brand, so I have it working with my nikon flashes, elinchrom lights, alienbees....
