09-13-2012, 09:43 PM   #1
halonp's Avatar
Af 360 not turning on
My flash unit has been working fine, I put fresh batteries in it today and it just won't turn on, no lights, no beeps, nothing.
I tried other batteries, checked and re-checked they were inserted correctly but nothing!
Anyone experienced this? Or have any recommendations? I really hope it's not dead, I love that flash!
09-14-2012, 03:48 AM   #2
calsan's Avatar
OK
I have a theory:
This may sound stupid, but AA batteries come in two lengths depending whether the country where they were made uses metric or imperial measurements.
There are AA batteries that are 2 inches long and there are AA batteries that are 5cm long.
2 inches is actually 5.08cm, so if you've got metric AA batteries that are 5cm long they will be shorter than the 2 inch long batteries.
Still with me??
What all that means, is that it's possible to have AAs that are too short and not pushing against the contacts in the flash...
So stand your new batteries next to the old batteries and check if they're exactly the same length...
If they're shorter - the solution may be to find new batteries the same length as the old ones.
09-17-2012, 07:00 AM   #3
slip's Avatar
QuoteOriginally posted by halonp Quote
I had the same problem with my sigma dg 500 super. I gave it a firm hit with the side of my hand a couple of times and it turned on. Not sure why, it still does it once in a while then I repeat the process. Try a dry eraser on the tongs that contacts the batteries as well
Good luck
Randy
batteries, flash, lighting, photo studio, strobist
Not turning on Jack L Visitors' Center 8 03-31-2012 12:38 PM
Monitor when turning K-5 on odyn Pentax K-5 3 05-29-2011 05:05 AM
Turning Off Electronic Level GregK8 Pentax K-5 7 02-14-2011 12:06 PM
Nature Turning Over an Old Leaf Sailor Post Your Photos! 7 01-01-2011 07:15 AM
Cityscape Turning Torso J_han Post Your Photos! 5 09-25-2010 09:20 AM
All times are GMT -7. The time now is 08:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
