09-15-2012, 12:28 PM   #1
brandonbpm's Avatar
handheld flash, soft and directional?
Hey, I was asked to take photos for an event taking place at a nightclub tomorrow night. Fortunately, the room will be dimly lit, as opposed to super dark with lasers that you see a lot. I could use my fast lenses and just use available light, but for group shots, I'll need flash in order to keep my iso down/shutter speed up. Normally my tried and true method has been on camera sb-26 with the flash tilted behind me and to the left or right bounced off the ceiling for a great result with soft directional light. unfortunately, the ceilings there are black and the walls will most like be very far most of the time, so I have decided I am goingto use radio triggered off camera flash, handheld for flash assisted shots. I don't have time to get a speedlight diffuser before tomorrow so I would like suggestions for making the light softer using my bare flash. it also has a built in bounce card and pull down diffuser, could those help?
09-15-2012, 01:49 PM   #2
baro-nite's Avatar
Making light soft means making it big. The bounce card and diffuser on the flash won't do that -- too small. It's why bounce flash works -- the wall or ceiling becomes the effective light source, and is much larger than the flash itself. You'll need a large diffuser or reflector, and some way to keep it in place. In a pinch I have used one of those round folding reflectors you stick behind a car windshield to shade the interior; these usually have a reflective side. Or you could bring along a large sheet of diffusing material, such as a sheet of thin packing foam. An assistant would be really helpful for holding the reflector or diffuser and maybe the flash too.
09-15-2012, 03:11 PM   #3
brandonbpm's Avatar
I have a large 5-in-1 reflector that also has a diffusion piece inside, would you suggest diffusing it or reflecting it more?
09-15-2012, 04:59 PM   #4
baro-nite's Avatar
An advantage of using the diffuser in this case is that you can probably position the diffuser closer than you could a reflector. That in turn makes the effective size of the light source larger, hence softer. On the other hand, light falloff will be more of a factor with a close-in diffuser, and for a group shot that can be a problem. Doing some experiments at home might help you figure out which will be the better choice for these circumstances.
09-15-2012, 06:42 PM   #5
slip's Avatar
I have a book where the guy was in the same situation, and he placed one of the men from the wedding party who had a white shirt where he wanted the flash to bounce, and he bounced it off his shirt. sounds weird buy it did work for him.
good luck
randy
09-16-2012, 04:33 AM   #6
baro-nite's Avatar
QuoteOriginally posted by slip Quote
I've tried that too. Certainly workable although requires more flash power than a reflector.
camera, diffuser, flash, light, lighting, photo studio, shots, strobist, time, tomorrow
Post sample photos from soft focus filters / how to make permanent soft focus filter. slackercruster Photographic Technique 6 07-08-2012 12:19 PM
Soft flash diffuser for AF360FGZ? cbope Flashes, Lighting, and Studio 9 01-15-2012 10:27 AM
Cityscape Directional, Directionless iocchelli Post Your Photos! 3 07-20-2010 07:39 AM
For Sale - Sold: Vivitar 2500 thyristor zoom flash; 58mm soft focus filter drabina Sold Items 5 07-01-2008 05:18 AM
For Sale - Sold: FF-Soft Case for Pentax AF 500FTZ Flash Wethphotography Sold Items 2 04-08-2007 07:20 AM
All times are GMT -7. The time now is 12:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
