Originally posted by slip I have read about the potentiometer, is it similar to a dimmer for lights?
Similar, it is a variable resistor in this configuration, quite hard to mess up. There are 3 connections on a normal potentiometer, one wire will go to the middle and the other will go to one of the ends. It doesn't really matter which end or which wires, if you don't like the direction it turns, just switch the wire to the other end. Even as useless as RadioShack is now, they carry a 100K potentiometer for $3.
