I saw somewhere here of someone's macro setup, wherein the flash is attached to a mini ballhead, attached to a flash bracket... I searched but couldn't find it again
Anyway, I have a flash bracket, and bought a giottos mini ballhead awhile ago... however, the thread for the ballhead is bigger than the screw on the bracket. How can I attach the ballhead to the bracket without breaking anything?
Also, to the macro shooters out there, what lighting setup do you use when available light is not an option? Mentioned above, I use a flash on a bracket (couldn't use the ballhead yet though), with a demb diffuser and flip-it to bounce light on the subject. Thanks!
