Originally posted by jatrax Lowell do you know if this passes through everything needed by the GPS unit? I was going to suggest that cable but I don't know if it will work for the OP's purpose or not. It would be good to know as I'm sure the OP is not the only person who might run into the same situation.
short answer, no, but only because I don't have a GPS. If someone offers me a GPS
then I can test. Seriously, there should be two PF members close enough together , one with the cable one with a GPS to figure this out but the cable does put all the contacts through to the secondary shoe.
Not sure the cable works with the OP's AF 360FGZ either, it is for the 500 and 540 for sure, but only because I have both flashes and checked the manuals. Maybe someone should ask pentax
