10-22-2012, 05:41 PM   #16
jpzk's Avatar
QuoteOriginally posted by steve1307 Quote
A lot of forums have the same question as yours . why does flash with HSS still give blurry wings. The answer is always the same, freeze with flash close in, low power. Dont need fast shutter.
I've browsed the links you provided ... seems OK ... I haven't given it a go yet: K5 at the repair shop - K7 not great for the lighting conditions we have here as of late -
I may try that when the K5 is back.
How "close" is "close", for the flash unit?
BYW, I am not as stubborn as you are !
JP
10-22-2012, 08:14 PM   #17
maxfield_photo's Avatar
QuoteOriginally posted by jpzk Quote
"Close" is the distance needed to make an 18% gray card to render @ 18% with the flash at it's lowest power setting (i.e. if you photographed just the card you want a spike right in the center of your histogram). In the case of the af540 that should be about 1 meter, maybe a little bit less.
10-23-2012, 07:22 AM   #18
jpzk's Avatar
QuoteOriginally posted by maxfield_photo Quote
That's good to know.
One metre seems like a reasonable distance: not too close, yet close enough.
Thanks for the info again.
JP
10-26-2012, 06:01 AM   #19
stormtech's Avatar
QuoteOriginally posted by SOldBear Quote
You don't want to trigger the camera's shutter release and the flash with one remote control. There is a good chance that the flash and the camera will be out of sync.
I'd use a set of remote control on one channel to release the camera's shutter. The camera in turn triggers the remote flash using another set of remote control on a different channel. This will guarantee the camera and the flash to be in sync.
I know I am bringing up an older post, but I wanted to add here that I figured out how to do what I want thanks to SOldBear's suggestion.
Using the Cactus v5 system, I would need four units. Two units set up normally for off camera flash with a trigger on the hotshoe and receiver on the flash. Then I found a cable so the Cactus v5 can be used as a remote:
Cactus V5 Shutter Cable for Canon Pentax Samsung - Gadget Infinity
Now with a second set of triggers set on a different channel, the receiver plugged into the remote port of the K-5, and the transmitter of the second set used as the wireless remote.
I already have the remote cable - now just need to order another pair of triggers and I am good to go!
bird, feeder, flash, hss, k5, lighting, photo studio, post, shoe, strobist
HSS GerryL Flashes, Lighting, and Studio 22 06-13-2012 06:55 AM
Remote Control F with K100D Question GibbyTheMole Pentax DSLR Discussion 2 11-25-2011 04:44 PM
remote flash question lucyrose Pentax K-r 3 01-16-2011 05:59 AM
question about remote assistant slip Digital Processing, Software, and Printing 3 01-15-2011 10:21 AM
istD remote question eccs19 Pentax DSLR Discussion 6 05-16-2009 09:55 PM
All times are GMT -7. The time now is 09:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
