Originally posted by jpzk In a nutshell, what you are saying is:
Set up the flash remotely at a decent distance so that the camera on-board flash will trigger it (the slave flash) and just use the "fastest" available shutter speed of 1/180s ?
Simple as that?
I would use the K5 + DA*300/4 + the AF-540 FGZ in my set up.
At which settings would you set the camera, e.g.: Av, TAv, ISO, etc ... ?
Thanks for the response.
JP
I had typed up an answer but my 3G signal just died and I lost it
Anyway, essentially yes a max_photo says and also to add.
I'd set it up with a model first to get the DOF right selecting your lens apeture and postioning your flash and setting the power.
If you're 6metres away then using f5.6 will give you only 3" of DOF. not enough?
Maybe f8, f11 would be OK.
The bigger the aperture you can use(keeping the dof OK) and the closer the flash can be postioned then the lower the power setting.
Since you can set up and test before I'd be inclined to use M-mode on the flash, its just more consistent. Hopefully you can get the right "subject" exposure with 1/64, 1/32 or maybe 1/16.
I always use M-mode in the camera when using flash (even with P-TTL). I can control the background ambient with varying shutterspeed.
Shutterspeed is not important for the lighting of the bird because the flash is going to do all the work.
Somewhere around here is a recent thread about the duration of the flash lighting on the AF540.
