Originally posted by Jonathan Mac Switch from PTTL to manual to eliminate the pre-flash. Use as low an ISO as you can and shoot RAW, so that exposure can be adjusted afterwards. Take as many shots as you can to increase your chances of being in focus.
This does not strike me as friendly advice: the whole point of TTL flash is that you don't have to worry about the flash output as well as everything else. You want to take pictures, not dick around with output levels until the exposure looks right.
For OP, however, you
do want to shoot with your mode dial set to M. It may seem counter-intuitive but it is set-and-forget. What you are saying, in effect, is "here is the shot that I'd like to take" and then it's down to P-TTL to make that shot possible. Suggested settings: F5.6, ISO 100, shutter speed: whatever, FEC: to taste.
Two flashes is a red-herring. All modern TTL flash systems work more-or-less the same. It goes like this:
- Tiny little flash to see how reflective everything is
- Calculate required output to expose the subject nicely
- FLASH!
This all happens in a split-second. YOU WILL NOT NOTICE IT (unless you've set something exotic like rear-curtain sync). Quick side note: if you've got some kind of strobist setup going on with off-camera flashes triggered by your on-camera flash, they
will notice the pre-flash; you can configure them to ignore it. The "flash!...FLASH!" you're seeing is red-eye reduction. Turn it off and point the flash head at the ceiling instead.
The other thing that you need to know about P-TTL (don't know about other TTL systems) is that uses an algorithm to calculate output that attempts to get as-close-as to correct exposure with in-camera settings and then adds flash on top. Basically, it boils down to this:
- If the camera is in control of shutter speed (Av, Sv) you get min(1/2f, 1/180). P-TTL flash predates IBIS so you get a "sensible" shutter speed.
- If the camera is in control of aperture (Tv, Sv) you're likely to get aperture set to wide open
- If the camera is NOT in control of either shutter speed or aperture but IS on control of ISO (TAv mode will make this so), ISO will go right to the limit.
I hope that this makes clear why "M" is the correct setting for flash photography: it is the only one that puts you in control.
