12-09-2012, 11:41 AM   #1
Flash problem on power 1/1, 1/2
Hi!
I need your help. I'm a beginner with strobes and I don't understand one thing: with this settings (iso100,1/180,f8) and a flash in slave mode, I obtain complete dark pictures if the flash is set on 1/2 or 1/1. With other powers it works. I don't understand it!
The flash is controlled in wireless mode with the built-in flash of my k5 (and i've also tried both the options to use the built in flash as a master or not (MENU/C3/21).
The subject was 1 meter away in front of the camera and the flash was set on the left of the camera.
Can you explain me where I mistake?
Thank you very much!
12-09-2012, 12:55 PM   #2
Anvh's Avatar
Does the flash trigger correctly?
Sounds to me the flash is going of with the "pre-flash" for the P-TTL metering and not with the main flash.
Also is your shutterspeed really 1/180 because 1/180 is not a "normal" shutterspeed you can get to.
12-09-2012, 02:53 PM   #3
Read this:
slave-flash-problem
12-09-2012, 05:34 PM   #4
Hi all! Yes, the shutter speed is 180, since I set 1/200 in manual mode, but when I pop-up the built in flash it automatically change the shutter speed to 1/180!
I didn't know about the preflash of the built-in flash for pttl! I mean, I thought that if I set the on-camera flash to wireless mode, it only controls the slave flash and doesn't have any influence in the scene.
So when I shot at 1/32 of the power, the flash has the time to recharge and fire again?! I really didn't thought!
Is there any way to block the pre-flash?
Thank you very much for the explanation!
12-09-2012, 09:22 PM   #5
Read this post (and the threads it refers to) for explanations as what happens when the built-in flash is set to wireless mode.
Note that in your case, the remove flash is triggered by any strobe from any source.
camera, flash, lighting, mode, photo studio, strobist
For Sale - Sold: Sears 55mm f2.8 1:2 M42 Macro w 1:1 adapter JeffJS Sold Items 11 09-21-2012 01:37 PM
For Sale - Sold: Vivitar Series 1 105mm 1:1 Macro f/2.5 (legendary lens) Bonobo Sold Items 38 05-11-2012 05:01 AM
OOF comparison (FA43, A50/1.2, K50/1.4, FA50/1.7, DA*55, FA77,FA*85) dgaies Pentax SLR Lens Discussion 99 05-15-2011 05:43 AM
For Sale - Sold: Your FA50 1.4 for my Sigma EX 50 1:2.8 1:1 Macro MrApollinax Sold Items 4 02-05-2009 09:33 PM
All times are GMT -7. The time now is 10:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
