Originally posted by SOldBear I replied to you in PM.
Thanks!
Originally posted by SOldBear ut here's an idea, farfetched but may work: use a ring flash that has focus-assist lamp.
If I went that way, I might as well get an old 330FTZ or 240FT that also has an AF spot beam (or use my Sigma 530 ST DG which has 1/16 power and a spot beam). I tried optical triggers and they do not work as well as I'd like. I could skip them and use the slave mode of my 500FTZ if I try that. But I often set one flash at 1/8 and the other at 1/32, I doubt 1/16 would be low enough not to interfere. I could always bounce the Sigma away.
So in short, there seems to be no integrated solution that can work above a radio trigger since the AF beam needs the whole set of pins to activate. So the solutions are:
1-get a flashlight
2-get a cheap Pentax flash with a spot beam (would it work when plugged directly on the camera, since it's TTL and not PTTL? Something to verify with my 500FTZ) and trigger the flashes as slaves
3-use my Sigma PTTL flash and trigger the others as slaves
4-To be confirmed : if somehow the spot beam can fire when mounted on the radio trigger, use a cheap flash with spot beam mode
5-Search some more
