Originally posted by Rusty There have been many suggestions on how to safeguard against the flash getting stuck on the camera - from internal adjustment to the pin in the flash to plugging the hole on the hot shoe. ... (snip)... Here's a simple solution ...(snip)... Just spray the hot shoe and the foot of the flash with a silicon spray ...(snip)...
I thought about that option (lubrication) in the past and even suggested it once (though not silicon spray). Sadly, I now don't believe this will help when it comes to stuck pins because the hole in the camera is nearly twice the diameter of the pin itself. In other words, the pin is not getting stuck in the hole itself.
Instead, there seems to be two dominate causes of this problem - the pin disengaging from the arm which lifts it and the plastic arm itself breaking. The first may be caused by people attempting to unlock the locking knob after trying to slide the flash off (pressing the pin tightly in it's hole) and the second may relate to warnings from Pentax about not to tighten the locking ring too tightly (especially on the accessory stand).
Regardless, the ultimate solution to both appears to be removing the four screws holding the stuck flash foot and then lifting the pin inside the foot manually as the flash shoe is removed. Those screws can be reached (I've done it) using a very thin, long-shaft, phillips-head screwdriver, with the camera carefully covered to prevent scuffs. Afterwards, the pin can be removed entirely, reengaged with the arm, or a broken plastic arm repaired with glue. If I were actually experiences such problems, my tendency would be to simply remove the pin entirely.
stewart
