Originally posted by stormtech Following along here as I am in the market for one more stand so I have a pair to work with.
My use would be for a speedlight and 16" softbox. I would also like to hear about a small boom as BrianR said about. I would like a small boom for the same speedlight/sofbox, but don't want to spend $75 for the dedicated boom/stands I've found so far.
I have one of these
Photoflex Telescopic Litedisc Holder - 36-67" DL-BHOLDER I had wanted the slightly smaller
Impact Telescopic Collapsible Reflector Holder 1103 B&H Photo but at the time I ordered the Impact one was out of stock.
The Photoflex works great on the Interfit stand I linked to above, but I'm hesitant to use it on the Manfrotto Nanos (the LumoPro LP605 linked above is a copy of the Nano that some say is sturdier). This boom/reflector holder has a hole to hook a counter balance on (always a good idea with an extended boom) and you need an adapter to attach a flash to the end as it only has a male 5/8" spigot at the end (no thread). An umbrella swivel works for this. While not as big and heavy as booms made to hold big monolights, it's hefty enough that I only travel with it when I'm sure I'll be using it and it works great with a speedlight+umbrella.
When shopping around be sure to search for 'reflector holder' as well as 'boom arm' as the main purpose of some of these is for reflectors even though they're suitable as smaller booms. Not all reflector holders can be used as boom arms for a flash though.
Having spent a few years wedging flashes between rocks or book cases or whatever was nearby I'm so much happier having spent a few bucks on some basic lighting support gear. The stands and boom arm above, and a couple of superclamps make positioning lights securely fast and easy. Remember when budgeting that stuff like this never becomes obsolete, and my only regret I have is that I didn't buy them earlier
